Gültigkeit Medical
Forum - Fliegerische Tauglichkeit
  • Hallo miteinander,
    bei mir wird im November diesen Jahres das Medical wieder fällig. Ich werde zu diesem Zeitpunkt dann 39 Jahre alt sein. Gehe ich richtig in der Annahme (da meine Medicals ja bisher immer 5 Jahre gegolten haben, ab 40 dann zwei Jahre), dass ich dann zu meinem 42 Geburtstag wieder beim Fliegerarzt erscheinen muss?
    Vielleicht hat jemand von euch auch die entsprechende Rechtsgrundlage da?
    Merci vielmals!
    VG, Tobias
    genau so ist es...trägt der Doc automatisch so ein
  • Top, danke dir :-)
    https://www.easa.europa.eu/sites/default/files/dfu/Easy_Access_Rules_for_Medical_Requirements.pdf
    MED.A.045 Validity, revalidation and renewal of medical certificates
    (3) Class 2 medical certificates shall be valid for a period of:
    (i) 60 months, until the licence holder reaches the age of 40. A medical certificate issued prior to the licence holder reaching the age of 40 shall cease to be valid after the licence holder reaches the age of 42;
    (ii) 24 months, for licence holders aged between 40 and 50. A medical certificate issued prior to the licence holder reaching the age of 50 shall cease to be valid after the licence holder reaches the age of 51;
    (iii) 12 months, for licence holders aged above 50.
    (4) LAPL medical certificates shall be valid for a period of:
    (i) 60 months, until the licence holder reaches the age of 40. A medical certificateissued prior to the licence holder reaching the age of 40 shall cease to be valid afterthe licence holder reaches the age of 42;
    (ii) 24 months, for licence holders aged above 40.
    (5) The validity period of a medical certificate, including any associated examination or special investigation, shall be calculated from the date of the aero-medical examination in the case of initial issue and renewal, and from the expiry date of the previous medical certificate in the case of revalidation.
    (b) Revalidation
    Aero-medical examinations and assessments, as applicable, for the revalidation of a medical certificate may be undertaken up to 45 days prior to the expiry date of the medical certificate.
  • Top, auch dir vielen Dank!
  • Die Dauer des Medical bei Verlängerungsuntersuchung wird beim AME oder AeMC durch die zentrale Vorgabe (=LBA-Server) gesetzt. In diesem Fall 2 Jahre ab dem Vierzigsten.
    Weitere zeitliche  Einschränkungen bei besonderen gesundheitlichen Konstellationen bleiben davon unberührt.
57.7 %
42.3 %
Stimmen: 376 | Diskussion
Aktuell sind 22 Besucher online, davon 2 Mitglieder und 20 Gäste.
fliegerrudi  lucabert
