WalterG schrieb:http://www.skydemon.aero/plan/documentation/routeanalysis.htmAirfield Plates
Hallo zusammen,
nutzt jemand von euch die Visual Charts in SkyDemon? Kann man diese aus der App heraus oder via WebApp drucken?
Gruss Walter
The Plates window is located to the right of the screen on your iPad
between the METAR and Flight Details tabs. On the PC it′s next to
Flight Details, or accessed through the Window menu on the toolbar.
When you plot your route VFR and IFR aerodrome charts, textual
information and visual approach charts are gathered by SkyDemon, which
can then be downloaded, viewed and printed if required.
To view a plate from an airfield along your plotted route open up the
Plates window and select the one you′d like to look at. It will be
displayed in PDF format. Once it′s loaded you will see a green tick next
to the icon
in the Plates window meaning it has been stored locally and is now
accessible in offline mode. This is especially useful to iPad users who
may want to view an approach chart or other textual information
in-flight.
When you have finished viewing the plate and would like to return to the
main map tap the screen, then select the ′Done′ button which will
appear in the top left-hand corner of the page.
Suchst Du danach?
Gruß UWE
